*messagefileset
Writes certain messages to a file.
*messagefileset type file
HyperMesh Tcl Modify Command
Writes certain messages to a file. All values below are case insensitive.
type
The type of message to write. Valid values are:
FEINPUT - any messages passed to HM by an FE-input processes.
HM - all supported type values.
file
The full path and filename of the file to write the messages to.
To save all FE-input error messages to a file named C:/test.dat:
*messagefileset "feinput" "C:/test.dat"
*messagefilefilter "feinput" "error"
   # Handle error
Version History
10-SA1-120
