*allsuppressactive
Sets the active/inactive state of all supported entities.
*allsuppressactive state
HyperMesh Tcl Modify Command
This command takes an integer state indicating the active/inactive status for all supported entities.
state
Indicates to set all supported entities as:
  • 0 - To active and to turn on their display.
  • 1 - To inactive and remove them from the display.
  • 2 - To active, but not to re-display them.
Examples
To set all supported entities to active and re-display:
*allsuppressactive 0
To set all supported entities to inactive:
*allsuppressactive 1
To set all supported entities to active and not re-display:
*allsuppressactive 2
Version History
9.0
