*createweldsbetweencompsusingpoints
Creates weld element(s) between pre-existing components at the given point(s).
*createweldsbetweencompsusingpoints comp1_mark comp2_mark single_col point_mark tol syst configval property null forced_length DTfile
HyperMesh Tcl Modify Command
- comp1_mark
 - The component mark for the first comp collector.
 - comp2_mark
 - The component mark for the second comp collector, if given.
 - single_col
 - Flag for the number of comp collectors used.
- 0 - Two comp collectors.
 - 1 - One comp collector.
 - point_mark
 - The point mark for the point collector.
 - tol
 - The maximum distance allowed between the point (from the point mark) and the comp (from the comp mark) in order to weld the elements in it.
 - syst
 - Systems flag.
- 0 - Do NOT build systems.
 - 1 - Build systems.
 - configval
 - Weld element type.
 - Property
 - Name of property collector. Used to retrieve property ID.
 - forced_length
 - For ACMs only.
- 1 - Sets Hexa length to be an average of two component thickness (t1 + t2)/2.
 - 0 - Creates hexa from element plane.
 - DTfile
 - Name of Diameter Vs. Thickness file. Used to calculate the size of Hexa elements in ACM and diameter for CWELD only.
Examples
*createweldsbetweencompsusingpoints(1, 2, 1, 2, 1.0, 1, 71, "myprop",0, 0, "DvsTfile")If the single_col flag equals 1, then comp2_mark is ignored.
