*updatefeatures
Specifies for element remesh with feature edges, if 1D elements selected as features are also refined.
*updatefeatures flag
HyperMesh Tcl Modify Command
This command specifies for element remesh with feature edges, if 1D elements selected as features are also refined.
Use of this command implies that it will be followed by a command that performs remeshing/meshing by elements with redo option selected.
- flag
 - 0 - 1D elements selected as feature edges are not refined (default).
To remesh elements 1-40 with element size 10 using 1D elements with IDs 100-110 as feature edges and create along these feature edges new, connected to created mesh, 1D elements with same properties:
*createmark elems 1 100-110
*elementsaddelemsfixed 1
*updatefeatures 1
*setusefeatures 1
*createmark elems 2 1-40
*defaultremeshelems 2 10.0 2 2 1 1 1 1 0 0 0 0 2 30
*setusefeatures 0
   # Handle error
}Version History
12.0.110
