*surfacemarkremoveallpinholes
Removes all pinholes of a specified size from the specified surfaces.
*surfacemarkremoveallpinholes mark diameter
HyperMesh Tcl Modify Command
mark
The mark ID containing the surfaces.
diameter
The upper-limit of the pinhole’s diameter.
To remove all pinholes of all surfaces using a radius of 5.
*createmark(surfs,1) all
*surfacemarkremoveallpinholes(1,5.0)
The *createmark() command is required.
