*createweldsbetweenelemsusingpoints
Creates weld element(s) between pre-existing elements at the given point(s).
*createweldsbetweenelemsusingpoints elem1_mark elem2_mark single_col point_mark tol syst configval property remesh
HyperMesh Tcl Modify Command
- elem1_mark
 - The element mark for the first element collector.
 - elem2_mark
 - The element mark for the second element collector, if given.
 - single_col
 - Flag for the number of element collectors used:
- 1 - One elem collector.
 - 0 - Two elem collectors.
 - point_mark
 - The point mark for the point collector.
 - tol
 - The maximum distance allowed between the point (from the point mark) and the element (from the elem mark) to weld this element.
 - syst
 - Systems flag:
- 1 - Build systems.
 - 0 - Do NOT build systems.
 - configval
 - Weld element type created:
- 2 = plot
 - 3 = weld
 - 5 = rigid
 - 21 = spring
 - 60 = bar
 - 61 = rod
 - 70 = gap
 - property
 - Name of the property collector. Used to retrieve the property ID.
 - remesh
 - Remesh flag (always zero).
Examples
*createmark(elems, 2) "all"
*createmark(points, 2) "all"
*createweldsbetweenelemsusingpoints(2, 2, 1, 2, 1.0, 1, 3, "myprop")If the single_col flag equals 1, then elem2_mark flag is ignored.
