*normalsreverse
Reverses the normals of 2D and 3D elements.
*normalsreverse entity_type mark_id size
HyperMesh Tcl Modify Command
entity_type
The type of entity to reverse. Valid values are elements and components.
mark_id
The ID of the mark containing the entities to reverse. Valid values are 1 and 2.
size
The size in model units of the normal display, if displayed as vectors.
To reverse the normal of element 15 using a display size of 10.0:
*createmark elements 1 15
*normalsreverse elements 1 10.0
   # Handle error
