*CE_SetSpecificDetailById
Sets a specific detail for a specific connector ID.
*CE_SetSpecificDetailById ce_id detail_type int_val dbl_val
HyperMesh Tcl Modify Command
ce_id
A single connector ID.
detail_type
The number for the connector detail you are editing:
Generic Connector Details:
  • 1 = thickness (integer)
  • 2 = user control (integer: 0 or 1)
  • 3 = state (integer: 1 = realized, 2 = failed)
Connector Line Details:
  • 101 = spacing (double)
  • 102 = density (integer)
  • 103 = offset (double)
  • 104 = half spacing (integer: 0 or 1)
int_val
Pass necessary integers values through this parameter.
dbl_val
Pass necessary double values through this parameter.
Examples
Note: A connector must be in user control mode in order to edit the state.
To change the thickness of the connector with ID 8 from 2T to 3T:
*CE_SetSpecificDetailById 8 1 3 0.0
To change the spacing for the line connector with ID 13 to 5.0:
*CE_SetSpecificDetailById 13 101 0 5.0
