*absorbmember
Absorbs existing 1D elements or lines to skeleton entities.
*absorbmember entity_type break_angle=<value> create_legs=<value> ?mark=<mark_id>? ?prefix=<value>?
HyperMesh Tcl Modify Command
Absorbs selected entities (1D elements or lines) to create members and memberjoints (from connecting nodes or points). If 1D elements are absorbed and they have a beamsection assigned to them, a membersection containing the beamsection is created and assigned to the member. No cleaning operation is performed at the end of the absorption.
- entities
 - The entity type to absorb. Valid values are elements and lines.
 - break_angle=<value>
 - The break angle limit (in degrees) to define if two continuous members may be merged into a single member.
 - create_legs=<value>
 - The flag defining if legs should be created on memberjoints. Valid values are 0 and 1.
 - mark=<mark_id>
 - The ID of the mark containing the entities to absorb. Valid values are 1 and 2.
 - prefix=<value>
 - The prefix for the member name.
Examples
To absorb displayed lines:
*createmark lines 1 displayed
*absorbmember lines mark=1 create_legs=1 break_angle=10
            To absorb elements ID 1-100 with a name prefix "top_":
*createmark elements 1 1-100
*absorbmember elements mark=1 create_legs=0 break_angle=10 prefix="top_"
   # Handle error
}Version History
2022
