*hf_setpartcomponent
Sets the specified component like the die module main part.
*hf_setpartcomponent entity_type mark_id
HyperMesh Tcl Modify Command
This command sets the specified component like the die module main part.
entity_type
The entity type. Must be set to comps.
mark id
The mark ID containing the component. Valid values are 1 and 2.
To set component ID 22 like the die module main part:
*createmark comps 1 22
*hf_setpartcomponent comps 1
   # Handle error
Version History
11.0
