*parsesolveroutputfile
Creates tables from solver output files.
*parsesolveroutputfile filename=<value> filetype=<value> extractdata=<value>
HyperMesh Tcl Modify Command
filename=<value>
The full name and path of the file to parse.
filetype=<value>
The type of file to parse. Valid values are:
F06
extractdata=<value>
The type of data to extract from the file. Valid values are:
fluttercurves - Collects flutter summary data and creates tables for pk and pknl methods.
To generate tables from the flutter data conatined in the file C:/temp/MSCFlutter.out:
*parsesolveroutputfile filename="C:/temp/MSCflutter.out" filetype=F06 extractdata=fluttercurves
   # Handle error
Version History
2019.1
