*AE_AttachmentCreateWithOptions
Creates attachments with options.
*AE_AttachmentCreateWithOptions target_entity_type target_mark_id location_entity_type location_mark_id search_type string_array number_of_strings
HyperMesh Tcl Modify Command
- target_entity_type
 - The target entity type to consider for adding attachments. Valid values are parts and comps.
 - target_mark_id
 - The ID of the mark containing the target entities. Valid values are 1 and 2.
 - location_entity_type
 - The location entity type to use for determining the attachment location (one attachment per location). Valid values are nodes. This is optional if doing a hole search.
 - location_mark_id
 - The ID of the mark containing the location entities. Valid values are 1 and 2.
 - search_type
 - Hole - If nodes are passed in via location_mark_id, attempt to find a single hole per node. If no nodes are passed, create an attachment for each hole found on entities in target_mark_id.
 - string_array
 - The ID of the array created using *createstringarray, which
            contains the additional input strings.  Must be set to 1.  Valid strings are:
- attachmentcontrol=<id>
 - The ID of the attachment control to use for realization.
 - maxdiameter=<value>
 - The maximum hole diameter to find.
 - mindiameter=<value>
 - The minimum hole diameter to find.
 - tolerance=<value>
 - The tolerance used for hole searches and projections.
 - number_of_strings
 - The number of strings in string_array.
Examples
Create an attachment for each location entity (nodes 266 and 380), looking for the nearest hole on Part1 or Part2 for each node:
*createmark modules 1 "Part1" "Part2"
*createmark nodes 1 266 380
*createstringarray 4 "mindiameter=5" "maxdiameter=25" "tolerance=25" "attachmentcontrol=1"
*AE_AttachmentCreateWithOptions modules 1 nodes 1 "Hole" 1 4
      Create attachments for each hole on 3 different parts, specifying an attachment control be created:
*createmark modules 1 "Part1" "Part2" "Part3"
*AE_AttachmentCreateWithOptions modules 1 nodes 0 "Hole" 1 4
      Create two node attachments (nodes 221 and 365), referencing specific nodes with no other realization:
*createmark nodes 1 221 365
*AE_AttachmentCreateWithOptions modules 0 nodes 1 "Node" 1 0
   # Handle error
}Version History
2020
