*penetrationrecheck
Modifies the element thickness to correct penetration problems.
*penetrationrecheck mark reduction scale display_mode normal_scale label segment magnitude_mode
HyperMesh Tcl Modify Command
mark
The mark of the entity to be modified.
reduction
The average thickness reduction.
scale
The thickness scale factor.
display_mode
The type of entity to be displayed.
  • 0 - Nodes
  • 1 - Normals
  • 2 - Contour
normal_scale
The magnitude percentage or the uniform size.
label
The label vector option.
segment
The segment orientation option.
magnitude_mode
Determines if a magnitude percentage or a uniform size is to be used.
  • 1 - Magnitude percentage
  • 0 - Uniform size
To modify the element thickness:
*createmark(groups, 1) "E2E"
*penetrationrecheck(1,0,1,0,1,1,1,1)
*createmark() and *templatefileset() are required.
None.
