*CE_PreviewDuplicates
Find duplicate connectors and place them on the output mark.
*CE_PreviewDuplicates outputmark tolerance
HyperMesh Tcl Modify Command
outputmark
Connector mark to be populated.
tolerance
Search radius to determine duplicates.
Examples
Duplicate connectors found inside a tolerance of 0.5 will be populated on output mark 1.
*CE_PreviewDuplicates(1, 0.5)
This command works similar to the preview empty or preview unused options in the HyperMesh Delete panel. The output mark should not contain any connectors prior to calling this command. The preview duplicates feature highlights all connectors that share exactly the same information within the specified tolerance.
