*clearpreservednodes
Clears the selected nodes that were marked as preserved.
*clearpreservednodes mark_id
HyperMesh Tcl Modify Command
This command clears the selected nodes that were marked as preserved.
mark_id
The ID of the mark containing the preserved nodes to clear. Valid values are 1 and 2.
Examples
To clear preserved nodes 1-4:
*createmark nodes 1-4
*clearpreservednodes 1
   # Handle error
Version History
13.0
