*xyplotonecurvemath
Performs a math function on a curve.
*xyplotonecurvemath function outputname xbased factor
HyperMesh Tcl Modify Command
function
The function being performed.
outputname
The name of the output curve.
xbased
1 - If the function should work on the x coordinate.
0 - If the function should work on the y coordinate.
factor
The factor to be used in the calculation.
None.
