Creates an FBD trace plot.
      *fbdtraceplot
        freebodygroup_id=<value> data_strings=<value>
          num_strings=<value>
      HyperMesh Tcl Modify Command
      This queries the GPF, Applied, SPC and MPC data from the result entity on a
        freebodysection.
          - freebodygroup_id=<value>
          - The freebodygroup entity ID.
          - data_strings=<value>
          - The ID of the string array that contains the additional input parameters. The string
            array is created using the *createstringarray command. This should
            always be set to 1.
          - Valid parameters and their syntax are:
                - appf=<value>
                - 0 - Applied forces do not participate in the FBD calculation (default)
                - 1 - Applied forces do participate in the FBD calculation
                - arrlen=<value>
                - Controls the FBD plot arrow length.  Default is 75 (%).
                - declim=<value>
                - Controls the decimal limit.  Default is 2.
                - displayat=<value>
                - 0 - Allong the cutting nodes (default)
                - 1 - Along the centroid of each freebodysection
                - fx=<value>
                - 0 - Do not display Fx forces (default)
                - 1 - Display Fx forces
                - fy=<value>
                - 0 - Do not display Fy forces (default)
                - 1 - Display Fy forces
                - fz=<value>
                - 0 - Do not display Fz forces (default)
                - 1 - Display Fz forces
                - gpf=<value>
                - 0 - Grid-point forces do not participate in the FBD calculation (default)
                - 1 - Grid-point forces do participate in the FBD calculation
                - intf=<value>
                - 0 - Internal forces do not participate in the FBD calculation (default)
                - 1 - Internal forces do participate in the FBD calculation
                - mpcf=<value>
                - 0 - MPC forces do not participate in the FBD calculation (default)
                - 1 - MPC forces do participate in the FBD calculation
                - mx=<value>
                - 0 - Do not display Mx moments (default)
                - 1 - Display Mx moments
                - my=<value>
                - 0 - Do not display My moments (default)
                - 1 - Display My moments
                - mz=<value>
                - 0 - Do not display Mz moments (default)
                - 1 - Display Mz moments
                - plotdir=<value>
                - 0 - Auto.  The direction axis is automatically determined on the basis of values
                  (default)
                - 1 - Global x-direction
                - 2 - Global x-direction negative
                - 3 - Global y-direction
                - 4 - Global y-direction negative
                - 5 - Global z-direction
                - 6 - Global z-direction negative
                - resfileid=<value>
                - The result file ID for resultid. Useful when multiple result
                  files are loaded for a single result entity.
                - resultid=<value>
                - The result entity ID.
                - scid=<value>
                - The results subcase ID for resultid.
                - scientific=<value>
                - 0 - Fixed format text (default)
                - 1 - Scientific format text
                - showvalue=<value>
                - 0 - Show text (default)
                - 1 - Hide text
                - spcf=<value>
                - 0 - SPC forces do not participate in the FBD calculation (default)
                - 1 - SPC forces do participate in the FBD calculation
                - stepid=<value>
                - The step/simulation ID for scid.
                - sumat=<value>
                - 0 - Along cutting nodes (default)
                - sysproj=<value>
                - 0 - Do not project the system along the plot (default)
                - 1 - Project the system along the plot
                - tolerance=<value>
                - The tolerance to limit the values. Default is 0.00001.
          - num_strings=<value>
          - Integer indicating the size (number of strings) in the data_strings
            array.
      Create an FBD trace
        plot:
*createstringarray 24 "scientific=1" "tolerance=0.00001" "scid=1" "resfileid=1" "resultid=1" "showvalue=1" "stepid=1" "fx=1" "fy=0" "fz=0" "mx=0" "my=0" "mz=0" "gpf=1" "appf=1" "spcf=1" "intf=1" "mpcf=1" "arrlen=75" "declim=2" "plotdir=0" "sysproj=0" "sumat=0" "displayat=0"
*fbdtraceplot 1 1 24
      Incorrect usage results in a
Tcl error. To detect
        errors, you can use the
catch
        command:
   # Handle error
