*CE_BoltAutoCreateFromAttachments
Creates bolt connectors from attachments.
*CE_BoltAutoCreateFromAttachments mark_id string_array number_of_strings
HyperMesh Tcl Modify Command
- mark_id
 - Te ID of the mark of attachments to create bolt connectors from. Valid values are 1 and 2.
 - string_array
 - The ID of the array created using *createstringarray, which
            contains the additional input strings.  Must be set to 1.  Valid strings are:
- ce_config_name=<name>
 - The name of the bolt config.
 - maxdiameter=<value>
 - The maximum hole diameter to find (default 25.0).
 - mindiameter=<value>
 - The minimum hole diameter to find (default 0.0).
 - only2layer=<value>
 - The number of attachments per bolt (default 0).
 - tolerance=<value>
 - The tolerance to use for attachment pair searches (default 50).
 - number_of_strings
 - The number of strings in string_array.
Examples
Create a bolt (general) connector from 2 attachments:
*createmark attachments 1 "attach_200_229" "attach_36_51"
*createstringarray 2 "tolerance=25" "ce_config_name=bolt (general)"
*CE_BoltAutoCreateFromAttachments 1 1 2
   # Handle error
}Version History
2020
