*ME_ModuleOccurrenceMoveContents
Move the contents from one module part to another.
*ME_ModuleOccurrenceMoveContents source_id target_id ?"option1=value1, option2=value2, ..., optionN=valueN"?
HyperMesh Tcl Modify Command
- source_id
 - The ID of the source module part whose contents are being moved.
 - target_id
 - The ID of the target module part receiving the contents.
 - options (optional)
 - List of input options, passed as a comma separated string enclosed in quotes. Valid
            options are:
- purge_target=<flag>
 - 0 - Keep the original destination part contents alongside the moved contents.
Delete the contents in part 40, and then move the contents of part 30 to part 40:
*ME_ModuleOccurrenceMoveContents 30 40 "purge_target=1"
   # Handle error
}Version History
14.0
