*modent_deletebymark
Deletes a mark of modular entities.
*modent_deletebymark entity_type mark_id keep_contents
HyperMesh Tcl Modify Command
entity_type
The type of modular entity to delete. Currently only supported for subsystems.
mark_id
The ID of the mark of modular entities to delete. Valid values are 1 and 2.
keep_contents
0 - Delete all contained entities
1 - Keep all contained entities and move them under the main include
Examples
Delete subsystems 4, 6 and 8 and move the contents under the main include:
*createmark subsystems "by id only" 4 6 8
*modent_deletebymark subsystems 1 1
   # Handle error
Version History
2020
