*fill_fe_gaps_elems
Fills gaps in FE from elements selected on both sides of the gap.
*fill_fe_gaps_elems mode mark_id1 mark_id2 max_width string_array number_of_strings
HyperMesh Tcl Modify Command
- mode
 - 0 - The input elements are the shell elements defining the boundary, and the gap boundaries are.
 - mark_id1
 - The mark ID containing the elements at the first boundary. Valid values are 1 and 2.
 - mark_id2
 - The mark ID containing the elements at the second boundary. Valid values are 1 and 2.
 - max_width
 - Maximum allowed gap width to be filled.
 - string_array
 - The string array ID that contains the additional input parameters. The string array is created using the *createstringarray command. This should always be set to 1.
 - number_of_strings
 - Integer indicating the size (number of strings) in the string array created using *createstringarray.
*createmark elems 1 "by comp id" 1
*createmark elems 2 "by comp id" 5
*createstringarray 2 "Remesh: 1" "DefineMaxWidth: 1"
*fill_fe_gaps_elems 0 1 2 100.0 1 2*createmark elems 1 12-18 55-100
*createmark elems 2 45-50 101-166
*createstringarray 4 "ByFeature:1" "Remesh:0" "DefineMaxWidth:1" "AdjacentComp:1" "GuideNodePairs:17 18 25 66"
*fill_fe_gaps_elems 0 1 2 10 1 4Errors
   # Handle error
}Version History
14.0
