*titlemodify
Modifies a title entity.
*titlemodify titlename itemname string value plot
HyperMesh Tcl Modify Command
- titlename
 - The name of the title.
 - itemname
 - The name of the item to be modified. itemname can be one of the following options:
 - string
 - The string value to which the modified item should be set. When itemname is titletext, the title displays a string.
 - value
 - The value to which the modified item should be set. Used for all itemnames, except titletext.
 - plot
 - Designates whether the title will be plotted after modification.
*titlemodify("test","borderon","",1,0)
*titlemodify("test","bordercolor","",4,0)
*titlemodify("test","titletext","This is test",0,1)
*titlemodify("test","titlefont","",3,1)
*titlemodify("test","titleanchor","",1,1)
*titlemodify("test","borderxmin","",0.469273743,0)
*titlemodify("test","borderymin","",0.120287253,0)
None.
