*splinesurface
Creates a 3D or planar surface defined by a set of lines, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of a Coons patch surface for the automesher to use under the mesh without surface option.
*splinesurface entities mark plane_flag plane options
HyperMesh Tcl Modify Command
- entity_type
 - The type of entities to use as input. Valid values are nodes, points and lines.
 - mark_id
 - The ID of the mark containing the input entities. Valid values are 1 and 2.
 - plane_flag
 - A flag indicating if the lines are planar.
 - plane
 - The plane used to project lines if plane_flag is set to 2.
 - options
 - Specifies options for creating the surface. Bit values are used and the value is
            calculated as (Bit0 + 2*Bit1 + 8*Bit3 + 1024*Bit10).
- Bit0
 - Component mode. Used to determine which component will be used to place created surfaces.
- 0 - Current component is used.
 - 1 - Component of input lines is used. If different components are used as input, the component to which the majority of the lines belong is used.
 - Bit1
 - Line ends usage mode. Used to control creation of vertices on the constructed
                  spline. Currently works only for planar surfaces.
- 0 - Vertices are created automatically on constructed surface.
 - 1 - Vertices are created at input line ends.
 - Bit3
 - Surface stitching option. Used to override the default stitching algorithm.
- 0 - Default stitching algorithm as defined by *setoption geom_stitching command.
 - 1 - Created surface is not stitched to any of model surfaces.
 - Bit10
 -  Mesh stitching option. Used to control the connectivity of the mesh created on
                  the new spline surface in simultaneous meshing modes set by
                    *surfacemode command.
- 0 - New mesh is not connected.
 - 1 - In *surfacemode 1, existing mesh nodes on input lines are used if new spline edges are stitched to those lines. In *surfacemode 2, existing mesh nodes on input lines are used to create the mesh on the new spline surface.
To create a surface from lines 65, 66, 67 and 69, with no elements:
*surfacemode 4
*createmark lines 1 65 66 67 68
*createplane 1 1.0000 0.0000 0.0000 0.0000 0.0000 0.0000
*splinesurface lines 1 0 1 1
   # Handle error
