*hf_DiePartPositioning
Repositions the model to avoid an undercut for the die module.
*hf_DiePartPositioning entity_type mark_id vector_id symmetry_flag plane_id reduce_depth reduce_undercut alignment_flag reposition_stamping reposition_CAD
HyperMesh Tcl Modify Command
This command repositions the model to avoid an undercut for the die module.
- entity_type
 - Must be set to elems. This is currently ignored.
 - mark_id
 - The mark ID containing the elements. Valid values are 1 and 2.
 - vector_id
 - The temporary vector ID created using the *createvector command that defines the normal direction. Must be set to 1.
 - symmetry_flag
 - 0 - No symmetry plane defined.
 - plane_id
 - The temporary plane ID created using the *createplane command that defines the symmetry plane. Must be set to 1.
 - reduce_depth
 - 0 - Do not reduce the draw depth.
 - reduce_undercut
 - 0 - Do not reduce the undercut.
 - alignment_flag
 - 0 - Do not optimize the blank area.
 - reposition_stamping
 - -1 - Do not tip the part in the stamping direction.
 - reposition_CAD
 - -1 - Do not tip the part in the CAD system.
*createmark elems 1
*createvector 1 0.0 0.0 1.0
*createplane 1 -0.586757294 -0.809460681 -0.022119755 -130.806 8.053 26.519
*hf_DiePartPositioning elems 1 1 0 1 1 1 0 1 -1Errors
   # Handle error
}Version History
11.0
