*create_thin_solid_midline
Constructs midline of a section cut through selected solids.
*create_thin_solid_midline solid_mark=<mark_id> ?<option1>=<value1>? ?<option2>=<value2>? ... ?<optionN>=<valueN>?
HyperMesh Tcl Modify Command
Constructs midline of a section cut through selected solids. The section cut plane can be defined using one of the following methods: by three nodes/points/sets of coordinates, by four nodes/points/sets of coordinates defining the corners of a finite rectangle or by two sets of coordinates defining the base point and the normal vector of an infinite plane.
The ID of the mark containing the solids. Valid values are 1 and 2. Non-thin solids will be ignored.
node_mark=<mark_id>
The ID of the mark containing the nodes defining the cutting plane. The mark should contain 3 or 4 nodes. Valid values are 1 and 2.
point_mark=<mark_id>
The ID of the mark containing the points defining the cutting plane. The mark should contain 3 or 4 points. Valid values are 1 and 2.
plane_by_point_coords={<value>}
The value should be a list of coordinates that determine the infinite or finite cutting plane. The array should contain 9 real numbers (3 sets of xyz coordinates) or 12 numbers (4 sets of xyz coordinates).
plane_base={<value>}
The list containing coordinates of the base point defining the infinite cutting plane.
plane_normal=<value>
The list containing coordinates of the normal vector defining the infinite cutting plane.
dest_comp=<value>
This option specifies which component the midlines will be created in:
current – Creates all midlines in the current component
midline – Creates all midlines in a component with the name “midline” (default)
midline.# – Creates midlines in components with names midline.1, midline.2, etc. corresponding to the components containing the original solids.
original – Creates midline for each solid in the same component as the solid itself. If the solid lies in several components, the midline will be created in one of these.
original.# – Creates the midline for each solid in the component with the original component name suffixed with 1, 2, etc.
within_comp_only – Do not equivalence between components. to_connected_surfs - Equivalence between selected surfaces and surfaces connected to selection.
within_selection – Equivalence only within the subset of selected surfaces
Examples
To create midline of a section cut for solid 131 determined by infinite plane passing through nodes 10, 11, 12:
*createmark solids 1 131
*createmark nodes 1 10 11 12
*create_thin_solid_midline solid_mark=1 node_mark=1
To create midline of a section cut for solid 131 determined by finite rectangle with corners defined by nodes 10, 11, 12, 13:
*createmark nodes 1 10 11 12 13
To create midline of a section cut for solid 131 determined by infinite plane passing through points 10, 11, 12:
*createmark points 1 10 11 12
*create_thin_solid_midline solid_mark=1 point_mark=1
To create midline of a section cut for solid 131 determined by infinite plane with a base point with coordinates (1.2, 3.4, 5.6) and a normal with coordinates (7.0, 8.0, 9.0):
*create_thin_solid_midline solid_mark=1 plane_base={1.2 3.4 5.6} plane_normal={7.0 8.0 9.0}
To create midline of a section cut for solid 131 determined by infinite plane passing through 3 points with coordinates (1.0, 2.0, 3.0), (4.0, 5.0, 6.0) and (7.0, 8.0, 9.0):
*create_thin_solid_midline solid_mark=1 plane_by_point_coords={1.0 2.0 3.0 4.0 5.0 6.0 7.0 8.0 9.0}
To create midline of a section cut for solid 131 determined by finite rectangle with coordinates (0.0, 0.0, 3.0), (0.0, 1.0, 3.0), (1.0, 0.0, 3.0) and (1.0, 1.0, 3.0):
*create_thin_solid_midline solid_mark=1 plane_by_point_coords={0.0 0.0 3.0 0.0 1.0 3.0 1.0 0.0 3.0 1.0 1.0 3.0}
   # Handle error
Version History
2022
