*createcirclefromcenterradius
Creates a circle or arc given the center and radius.
*createcirclefromcenterradius list_id vector_id radius angle offset
HyperMesh Tcl Modify Command
This command creates a circle or arc given the center and radius.
- list_id
 - The ID of the list containing the nodes to be used as center points. A circle or arc is created for each node in the list.
 - vector_id
 - The ID of the vector defining the circle normal, defined using the *createvector command. This must be set to 1.
 - radius
 - The radius of the circle or arc.
 - angle
 - The angle of the arc. To create a circle, set to 360.
 - offset
 - Sets the starting offset for an arc.
Examples
*createvector 1 0.0 0.0 1.0
*createlist nodes 1 18
*createcirclefromcenterradius 1 1 3.0 360.0 0.0Errors
   # Handle error
