*segmentsetaddshells
Adds selected 1D and 2D elements to a segment set.
*segmentsetaddshells name mark_id reverse_normals
HyperMesh Tcl Modify Command
name
The name of the segment set to update.
mark_id
The ID of the mark containing the elements to add. Valid values are 1 and 2.
reverse_normals
Create segment set:
0 - Along element normal
1 - Opposite element normal
Examples
Add elements 10, 11, 12 and 13 to segment set "test":
*createmark elements 1 10 11 12 13
*segmentsetaddshells "test" 1 0
   # Handle error
Version History
2020
