*pressures
Creates pressure loads on elements.
*pressures mark face nodes x comp y comp z comp magnitude break angle on face
HyperMesh Tcl Modify Command
- mark
 - The mark ID containing elements which should have pressures applied to them.
 - face nodes
 - The mark ID containing nodes which lie on the face of one or more elements (solids only).
 - x comp
 - The x component of the pressure.
 - y comp
 - The y component of the pressure.
 - z comp
 - The z component of the pressure.
 - magnitude
 - The magnitude of the pressure.
 - break angle
 - The break angle of a solid face.
 - on face
 - A logical which determines whether pressures are being applied to faces.
If you set x comp, y comp, or z comp to zero, a pressure is applied.
If you assign a value to x comp, y comp, or z comp, a traction is applied.
