*meshline_set_approximate_tol_factor
Sets the tolerance factor for approximating meshlines with NURBs curves.
*meshline_set_approximate_tol_factor tol
HyperMesh Tcl Modify Command
tol
The tolerance factor to use. Must be > 0.0.
To set the meshline tolerance factor to 0.5:
*meshline_set_approximate_tol_factor 0.5
None.
Version History
11.0
