*createfbdgroupfortraceplot
Creates a freebodygroup entity, used for FBD trace plots.
*createfbdgroupfortraceplot name=<value> node_ids=<value> entType=<value> num_cuts=<value> ?path_dir=<value>? ?userDir=<dx dy dz>? ?sys_id=<value>?
HyperMesh Tcl Modify Command
Options can be provided in any order.
- name=<value>
 - The name of the freebodygroup to create.
 - node_ids=<value>
 - The node IDs for the trace path, given in sequence. A minumum number of 2 nodes are required.
 - entType=<value>
 - Must be set to elems.
 - num_cuts=<value>
 - The number of cuts between each sequential node in node_ids. If 0 then sections are only created at the nodes.
 - path_dir=<value>
 - 0 - User direction
 - userDir=<dx dy dz>
 - When path_dir=0 , this is a triple double defining the direction vector.
 - sys_id=<value>
 - The ID of the system entity.
*createfbdgroupfortraceplot name=test node_ids={813 664} entType=elems num_cuts=0 path_dir=0 userDir={0.803557 0.595228 0.000000} sys_id=1*createfbdgroupfortraceplot name=test node_ids={813 664} entType=elems num_cuts=4 path_dir=1Errors
   # Handle error
}Version History
2019.1
