*bm_markpreservedcompsboundary
Flags the boundaries of components to be preserved during batch meshing and autocleanup.
*bm_markpreservedcompsboundary mark_id common_bound free_edges
HyperMesh Tcl Modify Command
mark_id
1 or 2 - The mark containing the desired components.
0 - Flag all components for preservation (not just the ones inside of a mark).
common_bound
0 - Boundaries between components within the selection are flagged.
1 - Only the boundary of the entire selection is flagged (comps are treated as a single set).
free_edges
0 - Free edges are not marked for preservation.
1 - Free edges are marked for preservation.
Examples
Mark the boundaries of components 100 and 101, flagging only the boundary of the entire selection:
*createmark comps "by id only" 100 101
*bm_markpreservedcompsboundary 1 1 0
   # Handle error
