*hf_EditPol
Opens the Section Editor and loads the POL profile into the 2D editor.
*hf_EditPol reserved
HyperMesh Tcl Modify Command
This command opens the Section Editor and loads the POL profile into the 2D editor.
- reserved
 - Reserved for future use. Must be set to 0.
*hf_EditPol 0Errors
   # Handle error
}Version History
11.0
