*fill_circular_holes
Fill flat circular holes on 2D elements.
*fill_circular_holes mark_id radius_limit
HyperMesh Tcl Modify Command
This command is used to fill flat circular holes on 2D elements.
mark_id
The mark of nodes on the holes to be filled. Valid values are 1 and 2.
radius_limit
The radius limit for holes to be filled. If set to a positive value, then all circular flat holes with radii less than this limit are filled. In this case, mark_id can be set to 0 and is ignored. Otherwise, all flat holes containing nodes marked are filled.
Examples
To fill the hole containing node 7989:
*createmark nodes 1 7989
*fill_circular_holes 1 -1.0
To fill the holes with a radius less than 5.0:
*fill_circular_holes 0 5.0
   # Handle error
Version History
10.0
