*create_batch_file
This command sets a limited set of cleanup parameters directly in the command file for use with *autotopocleanup.
*create_batch_file element_size element_type feature_angle pinholes_diameter layers_around_holes nodes_around_holesbeads_suppr_height max_edge_fillets_radius
HyperMesh Tcl Modify Command
Use this command to set a limited set of cleanup parameters directly in the command file for use with *autotopocleanup. Only a few automatic cleanup options are used; others are switched off or used with default parameters.
- element_size
 - The target mesh element size.
 - element_type
 - Mesh element types:
- 0 - triangle
 - 1 - quadrilateral
 - 2 - mixed
 - feature_angle
 - Elements feature angle used for features definition.
 - pinholes_diameter
 - Maximum diameter of the holes to be removed (filled).
 - layers_around_holes
 - Target number of layers of quadrilateral elements around the round holes (usually it is 0, 1, 2)
 - nodes_around_holes
 - Minimum number of nodes (element links) for round holes.
 - beads_suppr_height
 - Maximum height of beads to be totally suppressed (removed).
 - Max_edge_fillets_radius
 - Maximum radius of edge fillets to be removed (converted to hard corners).
Examples
- Element size - 10 mm
 - Element type - mixed
 - Element feature angle - 30 degrees
 - Remove holes with diameter less than 8 mm
 - Create 2 layers of quad elements around holes
 - Keep minimal 6 element links for the holes
 - Remove edge fillets with radius less than 9.0 mm
*create_batch_file(10,2,30,8,2,6,9 )
*createmark(surfaces,1) "displayed"
*autocleanup( 1, "nvh10.criteria" )
The cleanup parameters are deleted just after each use, so they must be set before every use.
