*tableaddcolumn
Adds a column of data to the right of a table.
*tableaddcolumn name data_type column_label string_array number_of_strings
HyperMesh Tcl Modify Command
- name
 - The name of the table to update.
 - data_type
 - The data type of the column. See *tablecreate for valid values.
 - column_label
 - The label of the column.
 - string_array
 - The ID of the string array that contains the column data to add. The string array is created using the *createstringarray command. This should always be set to 1.
 - number_of_strings
 - Integer indicating the size (number of strings) in the string array created using *createstringarray. This must equal the number of rows in the table.
To add a column of type integer and label INTEGER to "table1" which has 7 rows:
*createstringarray 7 1 2 3 4 5 6 7
*tableaddcolumn "table1" int INTEGER 1 7
   # Handle error
}Version History
11.0.101
