*updatepositions
Reorganize entities, in case of an add, remove, delete transformations or change in transformation order operations.
*updatepositions mark_id
HyperMesh Tcl Modify Command
- mark_id
 - The ID of the mark containing the position entities to refresh.
Examples
To update all positions in the model:
*createmark positions 1 all
*updatepositions 1
   # Handle error
}Version History
2019
