*setcuttingplanecolor
Sets the color of the base of the specified cutting plane.
*setcuttingplanecolor axis mode color
HyperMesh Tcl Modify Command
axis
The axis that is normal to the plane. Valid values are:
  • 0 - the plane with x-axis as its normal
  • 1 - the plane with y-axis as its normal
  • 2 - the plane with z-axis as its normal
mode
Sets the display mode for the specified cutting plane. Valid values are:
  • 0 - solid color
  • 1 - contours
color
The color to use when mode=0. Valid values are 1-64.
To set the cutting plane with y-axis as its normal to use solid color 24:
*setcuttingplanecolor 1 0 24
   # Handle error
