*criteria_write
Writes the global mesh criteria to a file.
*criteria_write filename
HyperMesh Tcl Modify Command
- filename
 - The name and path of the file.
Examples
To write the criteria to C:/temp/5mm.crit:
*criteria_write "C:/temp/5mm.crit"
   # Handle error
}Version History
2021
