*splitcontactfromcontactgroup
Disassociates a group (contact pair/tie) entity from a contact group.
*splitcontactfromcontactgroup id
HyperMesh Tcl Modify Command
id
The ID of the group entity to disassocaite.
Examples
To disassociate group 1 from the contact group:
*splitcontactfromcontactgroup 1
   # Handle error
Version History
2020
