*realizemasselementstosolvermasses
Creates nodal group solvermasses out of mass elements.
*realizemasselementstosolvermasses mark_id
HyperMesh Tcl Modify Command
Currently used in solver conversion from OptiStruct/Nastran to LS-DYNA.
mark_id
The ID of the mark of mass elements to convert. Valid values are 1 and 2.
Examples
Convert all mass elements in the model:
hm_createmark elems 1 "by config type" "0 1 1"
 * realizemasselementstosolvermasses 1
   # Handle error
Version History
2021
