*facedeleteduplicates
Deletes duplicate faces.
*facedeleteduplicates mark tol
HyperMesh Tcl Modify Command
mark
The mark ID which contains the faces to compare for and delete duplicates.
tol
The tolerance used to find duplicate faces.
To find and delete duplicates within a tolerance of 0.1, among the faces 2, 4, 7, 14, and 23:
*createmark(faces,1) 2 4 7 14 23
*facedeleteduplicates(1,0.1)
The *createmark() command is required.
