Generic ASCII Reader
This flexible format supports multiple data types (scalars, vectors, and tensors) spanning across various simulation types (linear, modal, and transient), and allows user defined labels for the data types. This generic ASCII reader is also available in HvTrans; therefore an H3D file can easily be generated for any of the custom results in the ASCII file.
Supported ASCII Formats
  • Nodal and elemental results.
  • Vector, tensor and scalar results.
  • 1D, 2D, and 3D elements.
  • Layer results for elements (composite results).
  • Centroidal and corner results.
  • Complex and non complex results.
  • Static, transient, and frequency response results.
  • Results on different systems like global, elemental, or user defined.
  • ID pools for elements/nodes.
Header Format
ALTAIR ASCII FILE
$DELIMITER=    <SPACE>/<TAB>/,    (except $ and #)
$TITLE=
$SUBCASE_ID =           id	“label”
$BINDING = ELEMENT or NODE
$LAYER_INFO =	num layers	“layer label”
$ID_POOL= “Nodes” or “Elements”
$SYS_ID = -1/0/user defined
$COLUMN_INFO=	ENTITY_ID GRID_ID
$RESULT_TYPE =  RES(v)(R/I)(Anim Source), RES(t)(M/P), RES(s)
$FREQUENCY =  1.00 Hz
$MODE = 1
$TIME= 10.0 sec
Data blocks OR
$INCLUDE  file path (which has the data)
