*createpointsbetweenpositions
Creates midpoints between two geometric positions in space.
*createpointsbetweenpositions x0 y0 z0 x1 y1 z1 count end_points system_id
HyperMesh Tcl Modify Command
- x0
 - The x-coordinate of the start position.
 - y0
 - The y-coordinate of the start position.
 - z0
 - The z-coordinate of the start position.
 - x1
 - The x-coordinate of the end position.
 - y1
 - The y-coordinate of the end position.
 - z1
 - The z-coordinate of the end position.
 - count
 - The number of midpoints to create.
 - end_points
 - 0 - No point at either end
 - system_id
 - The ID of the system that positions the end points in space. Use 0 for global.
Examples
To create 7 points between (1.89, 8.83, 8.84) and (8.68, 1.82, 1.83):
*createpointsbetweenpositions 1.89 8.83 8.84 8.68 1.82 1.82 7 0 0
   # Handle error
}Version History
2019
