*CE_ConnectorCreate
Creates spot connector(s) at the specified location(s) by mark.
*CE_ConnectorCreate entity_type mark_id
HyperMesh Tcl Modify Command
Creates spot connector(s) at the specified location(s) by mark. No links are added to the created spot connectors.
entity_type
The entity type that specifies the location to create connectors. Valid values are nodes, points, and lines.
mark_id
The ID of the mark containing the entities. Valid values are 1 and 2..
Examples
To create connectors at nodes 1, 2 and 3:
*createmark nodes 1 1 2 3
*CE_ConnectorCreate nodes 1
   # Handle error
