*linesplitatplane
Splits a group of lines at a plane.
*linesplitatplane mark plane id
HyperMesh Tcl Modify Command
mark
The ID of the mark containing the lines to be split.
plane id
The ID of the plane to be used in the split operation.
To split lines 10, 11, 12, and 13 to the plane defined by the normal (1.0, 0.0, 0.0) and base at (25.0, 0.0, 0.0):
*createplane(1,1.0,0.0,0.0,25.0,0.0,0.0)
*createmark(lines,1) 10 11 12 13
*linesplitatplane(1,1)
None.
