*morphhandlerotate
Rotates handles on mark.
*morphhandlerotate entities markmask plane angle sym con vari
HyperMesh Tcl Modify Command
- entities
 - Handles
 - markmask
 - Handle mark number
 - plane
 - Mark number of plane defined by base point and vector of rotation.
 - angle
 - Angle of rotation
 - sym
 - 0 - Do not use symmetry
 - con
 - 0 - Do not use constraints
 - vari
 - Type of rotation (see comments):
*morphhandlerotate(HANDLES,1,1,30.0,1,1,0)
      All handles on the mark will be rotated about the axis defined by the plane. This command differs from *morphrotatetrue() by the behavior of the influenced nodes. With this command the nodes follow the handles linearly.
If vari is 0, all the handles will be rotated by the given angle. If vari is 1, the handle farthest from the base point of the plane will be rotated by the given angle and the other handles will be rotated by the given angle times the distance of each handle to the base point of the plane divided by the distance of the farthest handle to the base point of the plane. The distances are measured normal to the plane.
If symmetry is used, all handles linked to marked handles by symmetry will also be rotated. If constraints are used, they will be applied to the rotations.
None.
