*findmark
Finds and displays entities or finds and displays adjacent entities.
*findmark entity_type mark_id function adjacent adjacent_entity_type numbers output_mark_id
HyperMesh Tcl Modify Command
This command finds and displays entities or finds and displays adjacent entities.
- entity_type
 - The entity types to find or to use for finding entities adjacent to.
 - mark_id
 - The mark ID containing the entities. Valid values are 1 and 2.
 - function
 - A flag that indicates the find function to perform. Bit values are used and the value
            is calculated as (1*Bit0 + 2*Bit1 + 4*Bit2 + 8*Bit3 + 16*Bit4 + 32*Bit5 + 64*Bit6
              + 128*Bit7).
- Bit0
 - Find mode.
 - Bit1
 - Find connectors and realized FE.
 - Bit2
 - Find tied contact entities.
 - Bit3
 - Unused
 - Bit4
 - Find free surface edges when finding lines.
 - Bit5
 - Find shared surface edges when finding lines.
 - Bit6
 - Find non-manifold surface edges when finding lines.
 - Bit7
 - Find suppressed surface edges when finding lines.
 - Bit8
 - Exclude group elements when finding elements.
 - adjacent
 - 0 - Add both entities on mark_id and those found to output_mark_id.
 - adjacent_entity_type
 - If function is 0, this should be the same as entity_type. Otherwise, it is the type of entity to find. The found entities will also be displayed. If set to undefined, all supported adjacent entities will be found.
 - numbers
 - 0 - Do not turn on numbers for the found entities.
 - output_mark_id
 - The mark ID to put the found entities on.
*createmark elements 1 12
*findmark elements 1 1 1 elements 0 2*createmark connectors 1 all
*findmark connectors 1 0 1 connectors 0 2*createmark lines 1 all
*findmark lines 1 240 1 lines 0 2Errors
   # Handle error
}Version History
2020 - Added new function Bit2 value..
