*beamsectionupdateshellpartname
Renames a HyperBeam shell section part.
*beamsectionupdateshellpartname beam_sect_id part_index new_name
HyperMesh Tcl Modify Command
- beam_sect_id
 - The ID of the shell beam section to update.
 - part_index
 - The index of the part to rename for that shell section, starting from 0.
 - new_name
 - The new name of the part.
Examples
*beamsectionupdateshellpartname 100 3 edge4Errors
   # Handle error
}Version History
10-SA1-130
