*attributeupdateentityidarray
Updates an attribute that is an array of entity IDs.
*attributeupdateentityidarray entity type id identifier solver status behavior targetentity data length
HyperMesh Tcl Modify Command
entity type
The type of entity that owns the attribute.
id
The ID of the entity that owns the attribute.
identifier
The identifier of the attribute.
solver
The solver number of the attribute.
status
The status of the attribute.
behavior
The behavior of the attribute.
targetentity
The type of entity to which the attribute refers.
data
An array of IDs to entities.
length
The length of the data array.
*createarray(4) 0 0 0 0
*attributeupdateentityidarray(loadcols, 1, 6436, 1, 2, 0, materials, 1, 4)
