*accepteditedsurface_with_user_tolerance
Moves surfaces from the midsurface to edit component into the middle surface component and stitches surfaces according to a specified tolerance.
*accepteditedsurface_with_user_tolerance auto_stitch tolerance
HyperMesh Tcl Modify Command
auto_stitch
= 0 - Auto-stitch is disabled.
≠ 0 - Auto-stitch combines surfaces using the specified tolerance.
tolerance
Surfaces within this decimal-value tolerance are stitched together if auto_stitch is enabled.
If auto_stitch is enabled but tolerance is less than zero, then the result is stitched with a tolerance of 1/5 the midsurface thickness.
To move midsurfaces from midsurface to edit into middle surface with a stitching tolerance equal to ¼ of the midsurface thickness:
*accepteditedsurface_with_user_tolerance(1,0.25)
